tien s-tec
yo talk to Terrence from cali...i think his sn is Terrance814 not sure tho. He has installed a set of every spring imaginable...or search some more ive seen multiple threads on spring installs...
Originally Posted by onebads2k,Dec 14 2004, 02:47 PM
does any one have directions and pictures on how to install any lowering spring? i tryed to search but it didnt work any advice would be must apriciated
i have a set sitting here just waiting to be put on. so i'm in the same boat you are.
onebads2k,
I just did this about a month ago with the same springs. I followed the directions in the link posted above. It is a pretty easy job. I chose to use a spring compressor even though some people don't. I just wanted to be safe. I does help to have an extra person from time to time as well. The only thing that was a pain in the ass was the rear driver's side spring. There are fuel lines running above the shock which makes it hard to get to the bolts to release it. But as long as you have some extensions, you should be okay. PM me if you need any help.
Chris
ps. I did cut the bump stops as per the directions that come with the springs.
Chris
