tire pressure gauge
Old Mar 3, 2013 | 03:04 PM
AZS2KDancer's Avatar
These all seem to be good gauges so far, but I'm still not seeing one that has 1/10th psi markings. Does it exist?
Old Mar 3, 2013 | 03:14 PM
S2KIrishman's Avatar
i have a digital bluepoint air chuck/pressure gauge that reads tenths....but that might be overkill for the non-mechanic since it was like 70 bucks from the snap on guy
Old Mar 3, 2013 | 03:17 PM
realblag's Avatar
http://www.longacreracing.com/catalo...st.asp?catid=8
Old Mar 4, 2013 | 04:06 AM
takeshi's Avatar
I use an Intercomp (analog, glow in the dark face, rubber hose, bleeder valve). Don't recall which model exactly. I'm not sure if it's one of the damped ones or not but I'd recommend it.
Old Mar 4, 2013 | 04:48 AM
Saki GT's Avatar
I prefer gauges and the ability to see pressure at points finer than a single psi, like tenths of a psi. I also prefer gauges with a rubber hose to get a proper fit and with a bleed valve. And I prefer analog to digital - you can see immediately if you've seated the gauge properly.
I like these features that you mention. Do you have any brands and models, or links that you can share to gauges that have analog tenths of a psi, rubber hose and bleed valve?
http://www.amazon.com/Accutire-MS-55...=cm_cr_pr_pb_t
When I said points finer than a single psi, I'm good with halves, but this does tenths too.
Old Mar 4, 2013 | 05:03 AM
dwight's Avatar
Originally Posted by deepbluejh
It works well and a half psi precision is good enough for me. I compared mine to two different gauges and they all read the same number. For $12 even if you want something better, it's still good as a spare.
Old Mar 4, 2013 | 10:20 AM
hand banana's Avatar
+1 for joes racing
CKit
Mar 12, 2012 11:16 PM
F22PwrdS2K
Dec 9, 2008 06:39 AM
glayden
Sep 20, 2006 10:42 AM
goblueS2K
Oct 20, 2004 05:41 AM
trypod
Feb 10, 2004 08:19 AM
