Top Speed...
Old Mar 8, 2004 | 03:19 PM
  #31
derwood03's Avatar
Originally posted by GeorgeP
In almost every test I have seen averaged for wind and road grade the earlier models did 146 mph. I was actually amazed at how consistent the number seems to be in most tests. The 04 seems to do about 149. I saw one 03 test at 148 so not much difference. When you get up to those speeds on a high drag car like the S2000 it takes a lot of power to add speed. One car mag took a specially prepped car with a lot of internal engine work to the Salt Flats and only managed 156 MPH.
Actuallly the car was prepared by westech, it was a stock S2000 with an AEM ECU, Comptech header and a Port&Polished head, no other mods. It did 154 MPH average speed ( a 3mile run down and 3mile run back) at Bonneville. Also it weighed in @3200 lbs, they had to add weight to the car.
Old Mar 8, 2004 | 03:24 PM
  #32
sydneysider's Avatar
I downloaded a home video from Kazaa demonstrating the top speed of the S2000. The guy hit 281kmph (175.6 mph), that was more than redlining on 6th gear.
The car was stock and pre-04.
If anyone wants the clip, it is only about 4 megs, but shows the dash and road very clearly. Alternatviely just search 'S2000' on Kazaa and you will find it, it's called "S2000 top speed". Looked like some scarey stuff.
He went by a truck at about 270kmph and you could only just see it flash past.
Old Mar 8, 2004 | 03:40 PM
  #33
KMKlint's Avatar
2002, top up, 150mph, cold air intake, sweaty steering wheel.
Old Mar 8, 2004 | 03:44 PM
  #34
xviper's Avatar
Not so sure about this part. When it originally posted here, it was said to have been a turbo.
Old Mar 8, 2004 | 04:01 PM
  #35
TunedS2000's Avatar
When does the speedo start to be inaccurate?
Old Mar 8, 2004 | 04:11 PM
  #36
wortham's Avatar
as far as i know, it can be a little off from the start, some more so than others. if you change out tires or gearing, then it starts getting even more so. it's what makes the yellow box useful so you can adjust your error accurately.
Old Mar 8, 2004 | 04:31 PM
  #37
xviper's Avatar
Wortham is absolutely correct. Speedo error is in terms of %. So, the faster you go the same % error translates into more mph error. The Yellow Box corrects in %.
Old Mar 8, 2004 | 08:43 PM
  #38
johninator's Avatar
[QUOTE]Originally posted by TunedS2000
so basically the pre 04 have a higher top speed?
Old Mar 9, 2004 | 03:58 AM
  #39
TrueDrezzer's Avatar
djohnston,
Nothing wrong with wringing out your car to its limit on the public Autobahn, if conditions are right of course. I was all by myself on a clear dry day heading to a trackday when I saw the 260. When I arrived, one fellow with a Z06 Vette told me he had hit 300 on the same road!
Tyres tend to "grow" at high speeds, so the speedo error increases as well. Error was probably well over 10%. I do remember hitting around 8300rpm when the dash showed 260.
With the top down, I can't even hit the rev limiter in 5th.
///Robin
dlq04
Apr 6, 2011 07:37 PM
cheshire_carper
Car Talk - Non S2000
19
Sep 11, 2006 04:33 AM
jmrobins
May 31, 2005 06:51 PM
goneverything
Sep 22, 2003 06:37 PM
S4 Mike
Jun 12, 2003 11:06 AM
