Track Event - Atlanta Motor Speedway - 12 August
Drive your car like it was meant to be driven! Join us on August 12 for some fun at Atlanta Motor Speedway. For more information check out the Chin Motorsport Group webpage: http://www.chinmotorsports.com/events/list.asp
Here's a link to people and cars that are already registered.
Let's see some more S2000s out there! http://www.chinmotorsports.com/participant...list.asp?eid=11
Here's the link to a previous announcement: https://www.s2ki.com/forums/showthread.php?...?threadid=18523
Originally posted by S2K_LA
Will our roll bar be enough to pass tech inspection?
You will be required to sign a waiver if the top of your helmet, like mine, is higher than the roll hoop.
Also, a tech inspection sheet needs to be filled out by a qualified mechanic covering items that should be in good condition on our cars since they're at most a couple of years old. The one item that you will probably need to attend to is to replace your brake fluid (must be done less than 30 days prior to the event), and to make SURE that you have enough pad material left (typically >75% thickness).
Here's a link to the tech sheet: http://www.chinmotorsports.com/forms/techSheet.htm
See you there!
Manuel NSX1164
06-06-2003 11:38 AM
CoralDoc
06-18-2001 04:33 PM
