Unusual Soft Top Tear
Old May 1, 2012 | 12:52 PM
deepbluejh's Avatar
I'll go ahead and tell you, it has a better chance of holding long term if you patch it from the outside as well as the inside. No, it doesn't look pretty, but it sure beats $1500 for a new top.
I delayed patching my top properly and I had a tear stretch from 1" long to 3" long. It now is very difficult to keep patched properly and I'll probably have to get it replaced. Far better to play it safe early
Old May 1, 2012 | 12:56 PM
OVER 9000!'s Avatar
Originally Posted by Spindash
+1 for the new modifry straps... I mentioned this in another post, but I use a tube of sealant that is made for repairing neoprene waders (usually can be purchased at outdoor products stores), and the stuff is extremely strong - I glued two pieces of convertible top fabric together and cannot rip them apart. You might give this a try, using a piece of top fabric much like in your picture.
Similar to this stuff:
Aqua seal
Do you know if it can withstand 100+ degree weather? That has been one of the big problems with the sealants I've used. Whenever it got hot out they would stretch and allow the top to continue to tear.
Old May 1, 2012 | 02:17 PM
Spindash's Avatar
Aqua seal
That's a good point, I can't say mine has experienced 100+ degrees yet, and rarely will. This summer I'll see plenty of 90+ days, but that doesn't help you out much... I can say though, that a frame bar passes over mine whenever I lower/raise the top, and the patch hasn't shifted or peeled a bit. It's designed to be permanent, dries pretty hard (still flexes though, for the neoprene) and has been stronger than black silicone in my experience.
Hopefully something can keep it solid, that heat's a killer!
Old May 3, 2012 | 11:12 AM
MaxInValrico's Avatar
$1500? Where you getting it from?
Old May 3, 2012 | 11:53 AM
RedCelica's Avatar
Originally Posted by Si Isnt Enough
You desperately need modifry straps
THIS...your straps are the reason your top's messed up...period. For the time being you need to manually pull the bar back each time you drop the top.
Top replacement is $818 + shipping + installation. There are a few guys on the forum that could help if they are in your area.
Old May 3, 2012 | 12:32 PM
OVER 9000!'s Avatar
I have the straps ordered and on their way! Do any of you guys know if the Robbins tops are better quality than oem?
Old May 4, 2012 | 03:39 PM
OVER 9000!'s Avatar
WHAT IS THIS BLACK MAGIC??!!
I installed the Modifry straps today and now the tear no longer stretches and it folds correctly!!! Could not be happier with this product!
Old May 4, 2012 | 03:46 PM
Disgustipated's Avatar
SHOCKING NEWS
Night raid
Jul 22, 2015 09:45 PM
noodlebaka
19
Apr 1, 2014 10:43 AM
OVER 9000!
Mar 20, 2012 12:36 PM
wdrx02
35
Jul 5, 2009 07:14 AM
Indecision
Oct 22, 2002 01:51 PM
