Used gears question
Old Dec 26, 2006 | 10:22 PM
tmkpres's Avatar
Default Used gears question
Well,
I ran into a great deal on some 4.77's. But I don't know about used gears. What is your guy's thought's on buying a set of used gears ??
Please let me know cause I would like the get them b4 they are gone !!
Thanks in advanced,
Victor
If this is the wrong section to post this then MODS feel free to move it where it belongs !
Old Dec 26, 2006 | 11:18 PM
s2k dre's Avatar
i would get them inspected for cracks and everything else, any machine shop can do it.
Old Dec 26, 2006 | 11:21 PM
tmkpres's Avatar
Thanks, I was also thinking of looking for stuff like that when i see them in person, to make sure that everything is cool with them !!
Thanks
Old Dec 26, 2006 | 11:26 PM
dyhppy's Avatar
i doubt there is much that would go wrong with them
Old Dec 27, 2006 | 12:53 AM
S2KPUDDYDAD's Avatar
Buying a used rear and buying a set of used gears are two different things.
I know your question is to buy or not to buy used gears but, I make this statement because, I would have no problem buying a used rear but, I would never buy a set of loose used gears.
Gears get a ware pattern (normal use) in them as they go round in the case. The longer they are used the greater this pattern gets. If you remove the gears and then put them back in or, put them in another dif case as you would be doing, they must be placed and reset to the exact same way they came out. If the gears are placed and set but, not to that ware pattern that is already there to begin with, they will wine more so than they did when new causing a harmonic imbalance, Gear wine!!
My 2 cents
Old Dec 27, 2006 | 07:48 AM
Stratocaster's Avatar
Used gears are very risky. Aside from the ware pattern, if they were not installed right the first time, they will never install right. You have less then 10 miles to get the install right. After that the gears are damaged and will never install right.
Don't be cheap on parts. The labor is the killer on the installation of these. I have seen new gear sets not setup right and you still have to pay the labor.
The question I have is why were they removed in the first place? It is cheaper to sell the diff and buy a replacement (swap) .
Old Dec 27, 2006 | 11:18 AM
SpitfireS's Avatar
tmkpres Posted on Dec 27 2006, 08:22 AM
Half the price but the trouble is doubled.
Buy some earplugs!
From a mechanical point of view there is not much to worrie about, IF the set is mechanically OK.
OK as in: the setup was correct from the beginning, the correct oil was used, break-in procedure was followed.
Setting up those used gears in a different diff housing will take a lot more trial & error (and $$ in labour) because it needs to be exactly right, there are most likely very small differences between diff housings and that is something that works against you.
Ring & pinion are a set, once the gears are used the diff housing they were used in becomes part of it.
Old Dec 27, 2006 | 05:42 PM
tmkpres's Avatar
I knew it was to good to be true, well guess I have to look at a new set instead.
Thanks for the heads up guys
9k all day
Sep 10, 2012 10:13 PM
s2kbtos
May 30, 2007 05:00 AM
ahbongkadah
Nov 24, 2005 05:56 AM
kriti2000
Oct 10, 2005 08:53 AM
Gr8nbed11
Feb 22, 2004 04:34 PM
