VAFC on s2000? is it applicable?
Old Oct 28, 2007 | 08:51 PM
nixeighty6's Avatar
Default VAFC on s2000? is it applicable?
in the instructions for the vafc, apexi says that s2000 is not applicable... page 15 of this http://www.apexi-usa.com/pdfInstallation/48.pdf. this is referring to the vafc I
why are people running these?
does my car need one with the vortech supercharger system?
can i take it off?
arn't vafc's notoriously unreliable?
thanks
Old Oct 28, 2007 | 08:54 PM
WashabiS2K's Avatar
the vafc v1 works fine on an s2000.
you don't "need" one if you are running a stock vortech unit, a little bit of FPR tuning should be fine right out of the box. you can take the unit off, and no, they are not unreliable (atleast in my case)
Old Oct 28, 2007 | 09:16 PM
Johnny Sack's Avatar
search is your friend.
Old Nov 1, 2007 | 01:12 PM
nixeighty6's Avatar
i tried to unhook the vafc and the car ran like crap, i hooked it back up and the car wont start... wtf
Old Nov 1, 2007 | 01:52 PM
WashabiS2K's Avatar
probably did something and jacked up your ECU wiring (reason why i bought a harness)
Old Nov 1, 2007 | 08:27 PM
nixeighty6's Avatar
it blow the alternater fuse... don't know how it did that but anyway...
when i disconected the vafc i took out the wires for the map and the vetec and attached them back togther, like factory, and took the main clip out of the vafc. left the battery negative off the car for i while, hooked battery back up and took it for a test drive, and it bouged at anything over 1/4 throttle.
after figuring out it was a fuse i hooked the vafc back up and im back to square one... i really dont want it on the car but i guess if i have to have it i'll try to take it to a dyno and see if it'll run right for now.
if i would take it off again, there isn't any tuning you can do with the vortech setup is there?
Old Nov 3, 2007 | 02:05 PM
gomarlins3's Avatar
I picked up 8 WHP and 6 lbs. tq. when I was NA with a VAFC.
wils2k
May 9, 2006 04:04 PM
ayelien
Jan 26, 2004 10:09 AM
NiN
Dec 7, 2003 11:44 PM
pfb
Feb 13, 2003 01:03 PM
ConeKiller
Feb 12, 2003 02:07 PM
