VSA what is that?
Old Aug 31, 2008 | 09:19 PM
gravitykills's Avatar
Banned
Default VSA what is that?
VSA what is that?
Are they on the newer s2k?
Old Aug 31, 2008 | 09:22 PM
mikeyr's Avatar
traction control
I believe 2006 and up.
Old Aug 31, 2008 | 09:40 PM
xedk's Avatar
^ yep yep
VSA = Vehicle Stability Assist
Old Aug 31, 2008 | 10:36 PM
G's Avatar
G
I have been told it is much better then the one in the TSX.
The 06 models also come with DBW - Drive by Wire
Old Sep 1, 2008 | 08:37 AM
SpudRacer's Avatar
Originally Posted by mikeyr,Aug 31 2008, 09:22 PM
traction control
Um no........Stability assist uses some of the same components that traction control systems use but it goes beyond helping the vehicle minimize tire slip to simply gain momentum. VSA or stability assist uses braking and throttle when the vehicle is in motion to control pitch and yaw with the intention of keeping all that momentum you generated from traction control headed in the direction you intended. The electronics will react faster than a human could ever hope to correct a skid by clamping down on one or more corners or modulating the throttle. Also when you step on the brake pedal, you don't have the option of clamping a single brake. You push the pedal and all four corners clamp. The VSA can clamp a single or multiple calipers as needed to correct the attitude of the car.
In the wet or on ice or in changing surface conditions, VSA is far better and safer than trying to catch a spin and compensate yourself. On the other hand, if you want to get the tail out on a track with a predictable surface, it can be a pain in the butt. That's why Honda designed the thing with an off switch. Personally, I keep it on all the time unless I specifically want to steer with the rear tires and throttle.
Old Sep 1, 2008 | 09:13 AM
energetic's Avatar
What is VSA? Well, here is the answer...
S2000with9k
Apr 20, 2023 04:25 PM
Steve3
Jun 1, 2006 07:36 PM
wampa
Dec 15, 2005 03:23 PM
Nickfromny
Nov 11, 2005 04:40 AM
koala
Sep 12, 2005 07:25 PM
