VTEC Problems in 1st gear!
Old Nov 13, 2006 | 06:17 AM
preilly44's Avatar
Default VTEC Problems in 1st gear!
Help! This doesn't happen every time but about one in four times when I reach about 6500rpms the engine cuts out almost as if the fuel cutoff activated. This is on an 03 s2k with 19k miles. It's only happened in 1st gear so far.
Has this happened to anybody? If so, what is the resolution?
Patrick
Old Nov 13, 2006 | 06:26 AM
Liebernoodle's Avatar
Does it happen to be right when you get in the car and start driving?
The car has to be properly warmed up before the VTEC engages. It seems as if the engine is hitting redline in 6500.
Just drive until your engine temp lights go on then you'll be fine to go up to 9k
Chazmo's Avatar
Uh oh. Check your oil level, Patrick. You might be low.
Otherwise, are you sure your cars warmed up to "three bars" before trying this? You shouldn't attempt VTEC on a cold engine -- and the ECU will slap you if you try.
Old Nov 13, 2006 | 07:54 AM
Woodson's Avatar
It's to save your car from you.
Old Nov 13, 2006 | 08:13 AM
melonheadr6's Avatar
I agree with Chaz, check that oil level!
djpeak10's Avatar
Yeah how would you like to be ripped out of bed and to be forced to run a couple of sprints.
Old Nov 13, 2006 | 09:19 AM
Sr2oD3's Avatar
Excellent way of stating it!
Old Nov 13, 2006 | 10:11 AM
C U AT 9K's Avatar
Either you didn't let the engine warm up or you're low on oil.
frankdatank91
Oct 7, 2012 09:12 PM
s2k_ed
Dec 11, 2008 01:34 AM
PyroFlick
Jun 6, 2005 12:09 PM
ITBs2k
Jun 6, 2005 09:11 AM
angrybee
Jun 21, 2002 05:00 PM
