Water leaking in through tops of windows!?
Old May 17, 2015 | 10:05 AM
kolyan2k's Avatar
Originally Posted by Abysm
Originally Posted by kolyan2k
Mine leaked on one side and Shin-Etsu didnt help, I just replaced one seal and problem solved. I believe part was about $40 bucks. Easy 10 minute fix.
It was this part for me:
http://www.hondapartsnow.com/genuine...1-S2A-013.html
Im starting to have the same problem with my weatherstrip however I don't have any idea about how to replace the part.. Could you possible help?
As far as I remember you just unscrew 1 or 2 screws and just pull it out. I've done it over a year ago. I also applied some additional weather sealer from parts store to make the seal seat tighter. No leaks anymore.
PS. my problem was that water somehow got inside the seal itself and then leaked inside the car.
Old May 20, 2015 | 12:01 PM
alSpeed2k's Avatar
Originally Posted by cosmomiller
If you check the car manual, there is a section in it for adjusting the windows. They are completely adjustable so you can get them to seat just right on the seals.
First, try the shin-etsu grease, then try this^! I just adjusted my window so the front of the drivers side moves up slightly higher.
Old May 21, 2015 | 07:17 AM
solitarycheese's Avatar
After greasing the seals, leave your windows cracked over night to allow the seals to "plump up". I keep my windows cracked whenever I can to allow the seals to maintain their shape.
cmn
Feb 24, 2008 12:46 AM
russellhq
Oct 16, 2007 11:19 AM
s2konroids
Aug 19, 2006 07:36 AM
jimpom23
Jul 30, 2005 12:13 PM
Rickjames
Feb 28, 2005 02:21 PM
