Water Pump replacement
Old Feb 23, 2001 | 09:39 AM
S2K_CLS's Avatar
well,
I had this squeaking noise from the accessory drive... dealer found it to be a water pump...
Nice thing about it is the quick turnaround and that is IS under warranty...
also, I get a new drive belt and my car would have been due for a coolant service soon (2 yr flush and refill)... thats getting done since they have to drain the coolant to do the water pump...
all in all, its a bit shocking to have one going bad after 17k miles, but good thing its under warranty...
Old Feb 23, 2001 | 11:28 AM
VA S2K's Avatar
Just out of curiousity, how exactly did it sound?
Old Feb 23, 2001 | 11:37 AM
S2K_CLS's Avatar
The best way to describe it would be a squeak during the revolution of the pulley...
maybe you've pushed a shopping cart around a grocery store and it has a bad wheel... goes squeak squeak at the same point in each revolution of the wheel?
the service advisor told me that they took the belt off and spun each pulley... the water pump made the exact sound I was hearing...
Old Feb 23, 2001 | 04:41 PM
joe_s2k's Avatar
That sounds about right(forgive the pun). RX-7's go through water pumps every 40K miles like clockwork. I have a feeling this one won't be as easy to remove.
Old Feb 24, 2001 | 03:15 PM
Utah S2K's Avatar
Had a Turbo II for 120,000 with only the original.....must have been lucky
Old Feb 25, 2001 | 03:03 AM
joe_s2k's Avatar
WOW! I had an '81(150k miles) and an '86(180k miles) and both went through water pumps at 40k miles. Maybe its the Texas heat.
I wanted a TurboII when they came out. Did you happen to get the special White anniversary edition? That was the one color that I liked the most. The Rotary engine was so smooth.
rob-2
Feb 16, 2019 12:13 PM
Define198
Sep 29, 2016 09:58 AM
DvS-
Feb 6, 2011 10:00 PM
JS2k.com
Aug 13, 2009 08:50 AM
btstone84
Jun 21, 2008 08:26 PM
