Weight reduction
Old Mar 27, 2006 | 10:17 AM
xviper's Avatar
Originally Posted by SheDrivesIt,Mar 27 2006, 12:03 PM
But X, it all adds up!
OK, your rebuttal is too overwhelming. I concede.
Prop rod, lugnuts, licence plate plugs, "H" emblems can all be replaced or removed.
Old Mar 27, 2006 | 10:31 AM
xviper's Avatar
Originally Posted by biker1,Mar 27 2006, 12:15 PM
It would be interesting to know if anybody else has gone down this route and any pit falls they had regarding mounting such an item.
You know I'm just "funning" with you, right?
Just make sure that the amp output is the same as the OEM alternator or you'll blow something. I also think the OEM alt has the voltage reg built in, so any other one you choose, you need to consider these sorts of things.
Old Mar 27, 2006 | 12:51 PM
biker1's Avatar
Hopefully should be able to get round both of those, just the mountings the difficult bit.
Thanks for the info.
Old Mar 28, 2006 | 07:15 AM
esoteric's Avatar
Don't let anyone give you too much crap on weight...
Every pound does count
https://www.s2ki.com/forums/index.ph...pic=331157&hl=
I have gone as far as removing my WS reservoir.
With wipers and all it's another 15lbs or so gone.
The cruise would be in the bucket already too, except that the cruise bracket and the coolant reservoir are on the same bracket. And I haven't come up w/ a good block off plate for the buttons on the wheel.
SC_Highlander
Oct 13, 2012 08:12 PM
dsthez
Mar 8, 2011 11:55 AM
zyr
Dec 7, 2006 06:22 AM
ProV1
Oct 25, 2005 01:18 PM
Sub-Zero
May 2, 2005 05:05 PM
