weird headlights and windshield condensation (fogged up)
Old Mar 11, 2012 | 05:57 PM
lopez14's Avatar
Default weird headlights and windshield condensation (fogged up)
So I just went out side and started my s2, turned my lights on and left it running for like 5 minutes, i put the top down. Then moved it like 5 feet forward. I then put my roof back on, turned off the lights, then shut it off and went back inside. 10 minutes later i got outside and see it and my whole windshield is all fogged up from the inside but just the windshield no other window. And then my headlights were fogged up too but not completely. They were only fogged up on little spots throughout the headlight and each fogged spot had a drop of water on the outside of the headlight, like if the headlight would have sucked up the drops of water through the plastic? Any one know what happened? Or if its going to get out of my headlights. I just paid like 500 bux a week ago for them
Old Mar 11, 2012 | 06:14 PM
ahrmike's Avatar
if the air was humid, humid air will enter your headlight. drop of water = cold, so it condenses the water from the inside. Don't worry about it - there are breathers in the back of the light that allow the moisture to escape as you leave your headlights on and the inside heats up.
Old Mar 11, 2012 | 06:24 PM
lopez14's Avatar
yea the air is humid because its been raining all weekend and does that work for aftermarket headlights too? i have an ap1 but it has those aftermarket ap1 fitment ap2 look headlights. I think it has those little breathers that you are talking about too so should i not worry about it?
Old Mar 11, 2012 | 09:35 PM
ahrmike's Avatar
yes, you shouldn't worry too much about cloudy in small area stuff. Start worrying when you have water in the headlights (usually due to a bad seal). A bit of condensation is normal since the headlights are not truly "sealed"
REV59K
17
Mar 28, 2010 08:34 PM
darkwatch
May 29, 2008 08:33 PM
Formula
Dec 5, 2005 08:37 AM
VTECturbo04
Sep 12, 2004 02:20 PM
highrev
Aug 27, 2003 11:55 AM
