what Brake fluid to use?
Old Jul 20, 2008 | 10:01 AM
AeroS2000's Avatar
Default what Brake fluid to use?
what is the best one to use. im changing my clutch fluid cause its getting really dark
Old Jul 20, 2008 | 10:13 AM
johnanderson's Avatar
I just bought some of the factory dot 3 to change out both my brakes and clutch. It all depends on if you track or autox the car. If you do then you should probably go with dot 4 because of better temp specs. Otherwise if you dont want to change it out often then get dot 3. If you dont want to buy the honda stuff then any dot 3 brake fluid should work.
Old Jul 20, 2008 | 10:59 AM
tekstar's Avatar
there is no benefit in using a dot4 over a dot3 for your clutch fluid
Old Jul 20, 2008 | 11:05 AM
Whoops, my bad. I just bought them to flush both my brakes and clutch and my mind was wondering.
S2KBert
Apr 28, 2015 06:17 PM
Erriseehuang
Aug 11, 2011 09:30 PM
TheLast13
Feb 11, 2011 04:36 PM
S2kRally
Sep 24, 2010 04:23 AM
s2000ky
Jul 22, 2008 10:39 AM
