What size bolts for T1R test pipe install?
I need the size of the stock nuts and bolts for the cat so I can install a T1R test pipe (I can't reuse the stock ones). Also will I need an exhause gasket? If so where can I get one? Thanks
rear 3 bolts? I got a berk test pipe and the bolts that came with it fit fine, but someone on the gb page posted they got 3/8" x 1 1/4" & 3/8" x 1 1/2 for the top bolt. The front 2 spring bolts, I just reused the stock ones. Gasket, you could try to message berk to see if they'll sell you a 3bolt gasket, but he also mentioned that the oem rear gasket worked though it looked like it wasn't a tight fit.
So I could just reuse the OEM gasket and I'll be ok? If not could I just get a gasket from honda? I know sometimes car companys wont let you but just the part you need rather you have to buy the entire assembly...
Ryan
