Wierd Clutch Noise
i hear a weird clutch noise every time i shift to each new gear.. only when i release the clutch i hear it though.
example: start off in 1st gear.. release clutch .. then i hear the noise 1/2 way into releasing the clutch.. then shift to 2nd gear, then hear noise 1/2 when releasing clutch again.. then 3rd gear.. etc..
is this normal... it sounds like little tiny beads or rubber or something.. no clue
bump
i randomly get this soud on my 07 too and I just got it two days ago but I thought maybe its just normal noise since the tranny is right under me and im used to driving my fwd hatch where everything is so far away from me up front
I think that it's normal... I could hear my clutch "sing" under me but my first 100 miles on the car last night. The sound was what you described so it could be normal. After driving a while it went away for me.
You gotta post more info if you want help. Your profile doesn't tell us what year you are driving, and it should. Also what's milage. Give every detail, and you're much more likely to get an answer. Finally describe the noise better...
i dont think im a purchased member thats why it dsnt show what year im driving.
but its an 00 with 115k miles.
i cant really describe the noise cause i dont really know what makes that noise..
its hard to explain but shouldnt the Time it makes the noise be enough to diagonise it? cause it only makes the noise Exactly AT the SAME time at the Same moment in Every gear.. that should narrow it.
if anything no ansewr comes up.. ill just not worry about it and just keep driving
Saki GT
Sep 15, 2014 08:39 AM
