Air Filter!
Old May 25, 2007 | 09:52 AM
B SweepeR B6's Avatar
Default Air Filter!
hey guys i ahvent' changed my intake filter since the car was bought (25k's miles on it) and its time for me to do so. where can i replace it? i dont really wna pay 90 bucks for that stuid filter. thanks.
Old May 25, 2007 | 09:56 AM
Saki GT's Avatar
Which air filter? There are two.
I bought a K&N intake for the engine - about $50 at any auto parts store and you can clean it each year rather than replace it outright like the OEM paper cone (should be about $30 - where are you seeing $90!!??).
The cabin air filter I bought online from handa accessories.
You can probably benefit from changing both.
Old May 25, 2007 | 10:03 AM
nevr eknew of a cabin one but I was talking bout the intake one. that stuipd yellow crap thats dirty as **** with some cuts in it. 50 for a K n' N? its drop in right/
Old May 25, 2007 | 10:07 AM
Saki GT's Avatar
Yes, drop in (slide it on actually), then you buy a recharge kit (oil) and clean it annually. Saves money after 1 yr.
Old May 25, 2007 | 10:08 AM
nicee. whats the other filter exactly do?
Old May 25, 2007 | 10:12 AM
GOS2K007's Avatar
Filters air coming into the cabin.
Old May 25, 2007 | 10:21 AM
where is that located? and how much is that n how often does it get cleaned (i mean should be replaced)
Old May 25, 2007 | 11:22 AM
blackout's Avatar
It helps keep the cabin from smellin like crap when you got air going if theres anything outside the car or if you smoke inside the car, keeping the filter fresh will help eliminate some of that smell. Not sure if the cabin filter works on all modes from the HVAC controls but perhaps someone could enlighten you.
Just a side note for everyone but filters FILTER better when they are dirty. This increases its filtering efficiency up until the point that it reaches its saturation point and starts blowing debris through.
As far as the engine air filter goes this point is pretty much null and void since you want as much air going through as possible, tiny particulate is generally not harmful, however the cabin filter benefits from being dirty as it helps filter more. Just make sure it doesnt get too dirty and cause too much of a pressure drop and hence strain on the blower motor
Old May 25, 2007 | 01:56 PM
2slow's Avatar
Here's a DIY thread about changing the cabin air filter:
https://www.s2ki.com/forums/index.php?showtopic=145495
For some reason I can't see the pictures at the moment.
Anyway, I got it from the FAQ/DIY section in the Under the Hood Forum.
rrounds
Jan 14, 2012 09:13 AM
8kGoodENuff
Aug 7, 2006 03:01 PM
161MPHTOPSPDS2K
Feb 13, 2006 09:37 PM
da_illist_onE
Dec 4, 2003 09:42 PM
scargo
Sep 10, 2003 10:21 AM
