Clutch, Transmission, or something else?
Old Oct 23, 2007 | 12:39 PM
MrScheib's Avatar
Default Clutch, Transmission, or something else?
I was driving my car which is a MY2000, I stopped at a stop sign. I got on it till redline, shifted to second and I guess I didn't get it all the way in to gear and it popped out. Then when I put it in second its instantly started making a grinding noise, so I shifted to third and same thing. I pulled over put it back in to first started to let the clutch out slowly and started making the same grinding and wouldn't hardly move. Any thoughts? I know its impossible to diagnos it with out hearing the noise for youself or inspecting it, but just thought someone has had this problem. Thanks in advance!
Old Oct 23, 2007 | 12:45 PM
animeS2K's Avatar
is it a rotational grinding? only when the car is moving? only when the clutch is engaged or also when it's disengaged?
can you easily shift the car while the engine is running, but it's not moving?
Old Oct 23, 2007 | 12:48 PM
MrScheib's Avatar
Yes it only when it is moving. It goes in to the gears the same as it did before.
Old Oct 23, 2007 | 04:14 PM
animeS2K's Avatar
Does it make the noise when you're not in gear?
Old Oct 23, 2007 | 05:25 PM
MrScheib's Avatar
Nope it doesn't make the noise when in neutral.
Old Oct 23, 2007 | 08:02 PM
animeS2K's Avatar
Ok, that *should* rule out the differential.
So you're looking at your transmission and the engine-side of the transmission.
Old Oct 24, 2007 | 03:46 AM
S2KPUDDYDAD's Avatar
Can you here were it is coming from the?? maybe get a friend outside the car to listen as you move forward. Do you have the noise in reverse?
Old Oct 24, 2007 | 08:46 AM
MrScheib's Avatar
The noise is in every gear. It sounds like it is coming from some where in the rear in the middle. If you creep alittle ways it will stop for a split second and then start again.
Old Oct 24, 2007 | 08:52 AM
animeS2K's Avatar
Yeah i think this needs a local member or mechanic... Again, pretty much impossible to figure out online
Old Oct 24, 2007 | 09:08 AM
MrScheib's Avatar
ya thats what I figured, but thought it was worth a shot. Thanks for the help you guys!
sandul12
Jul 18, 2015 12:39 AM
b20eg2
Aug 25, 2014 08:27 AM
StatixNWH
Feb 19, 2007 10:07 PM
sarahj12
Feb 14, 2004 08:28 PM
S2k Dude
Feb 8, 2001 09:19 AM
