Will my battery explode?
Old 11-18-2007, 03:30 PM
darkwatch's Avatar
Default Will my battery explode?
so my car has been in winter storage for a while now and it has started to freeze alot and my grandpa say that my battery will freeze and explode in my car because i just unhooked it and didnt take it out... should i go take it out or will it be fine?
Old 11-18-2007, 03:35 PM
IDO914S's Avatar
If you purchase a battery tender you will be fine.
Old 11-18-2007, 03:42 PM
jeggy's Avatar
even if a battery freezes, it will not explode. it will swell and bulge but it will not explode from the cold.
once it freezes, it's pretty much a bad battery.
just bring the battery inside the house.
Old 11-18-2007, 04:04 PM
gbaker's Avatar
I have a couple of battery maintainers/minders. One for my car over the winter and one for my grandmothers florida car when she is up north for the summer.
They work by monitoring voltage and when the voltage gets low (about 12.5 volts) they will kick on and supply 1-1.5amps for a few seconds and turn off at around 13.5-14 volts. They keep cycling for as long as they are connected, and maintain full battery charge even while the battery is still connected in the stored vehicle. They will not boil the water out of the battery.
I got mine at WalMart for around $35.00. A fully charged battery (in the lower 48) usually doesn't freeze up.
A great item.
Old 11-18-2007, 05:23 PM
JonasM's Avatar
Battery tenders are the best thing to do. I'm cheap, so I just bring it inside, put in on a shelf in the basement, and put in on a charger in the spring bef9ore reinstalling it. Mine is 6 years old (23K miles) and going strong.
JonasM
Old 11-18-2007, 06:03 PM
Ks320's Avatar
Batteries should only explode if you chuck them into fire or if you short-circuit them -- I think?
Old 11-18-2007, 06:18 PM
MitsukillinS2K's Avatar
i am pretty sure those two are the only way to blow one up.
i wish i could store mine for the winter, but i have no garage yet but one day i will
Old 11-18-2007, 06:27 PM
icemans2k02's Avatar
if it does blow up take pictures..
joking. for peace of mind you could always take it out
Old 11-18-2007, 07:38 PM
jeggy's Avatar
they can also explode if you overcharge them.
a while back, a few guys and myself took a 3/4 wrench and stuck it between the - and + terminals.
it swelled up and started oozing out the top.
technically it didnt explode.
Old 11-18-2007, 07:43 PM
ShocK's Avatar
"Don't leave a discharged battery in below-freezing conditions. Its electrolyte is basically just water, and it will freeze and damage the plates inside. Bring a discharged battery into a warm environment as soon as possible. Then charge it immediately, even if this means removing the battery from the vehicle or towing the vehicle to someplace where it can be brought inside." courtesy of msn news site.
Quick Reply: Will my battery explode?
