Wrinkles in Convertable Top
Old Sep 13, 2002 | 09:07 AM
SilverS2KAZ's Avatar
Default Wrinkles in Convertable Top
Sometimes I just put the top UP without locking it down with the hooks. When I do this, the top tends keep the wrinkles it gets from being compacted while in the down position. If I use the hooks and lock the top when it is UP, it stretches out enough so that the wrinkles go away.
The wrinkles apear on the sides of the convertable top.
The wrinkles I'm thinking MIGHT be a result of the climate being so dry here in Arizona. Perhaps the moisture from humidity would inhibit the wrinkles form forming in the first place.
Is everyone getting wrikles in their top?
Old Sep 13, 2002 | 09:16 AM
RWIRSING371's Avatar
Yes, all the time. What happens is the material is made to "flex" so when you put the top up and lock it, this strecthes the material. I had this problem on my Eclipse spyder. For new top owners who have had their tops replaced somestime it will sink in a little--this means the top has been cut too long or I should say too much material left over and not installed tight. If you have this problem go to the dealer but for wrinkles put the top up they will go away.
Old Sep 13, 2002 | 09:21 AM
Flyin Wedge's Avatar
Not sure I understand why you would "sometimes just put the top up without locking it down"...you mean if you park it for a short time in the sun or something?
Old Sep 13, 2002 | 09:46 AM
auDD's Avatar
I have wrinkles on both sides of the top and in the bottom corners of the window. Is this abnormal, and if so, would a replacement be covered under warranty??
Old Sep 13, 2002 | 10:03 AM
Euclid's Avatar
I see the same thing when I leave my top down for an extended period of time, and then close it. There are wrinkles on each side of the top. They go away after having the top up for a while. I would imagine this is normal since the top was folded.
Old Sep 13, 2002 | 10:50 AM
Correct. Short periods of time only
Old Sep 13, 2002 | 12:23 PM
Yea,I get wrinkles in mine as well on the left and right side by the rear window,flattens out in a day after the top is up.
Old Mar 12, 2007 | 11:17 AM
07s2kap2's Avatar
oohhh good i thought i would have to stick an iron to it or something lol
Old Mar 12, 2007 | 12:10 PM
S2KBG's Avatar
i am guessing that there is a difference in the softtop material between AP1 and AP2 because in my case i am the second owner,the first put a hardtop from day one and never took it off.I just recently remove it to enjoy the FL weather,which makes about 3 years total after purchase new and NO wrinkles whatsoever,none.I was a little conserned about how it would look but now i am relieved...
ManOnFire75
Aug 6, 2013 11:47 AM
snakeeater
Jul 16, 2008 07:25 AM
RunUrAss
Dec 18, 2006 10:28 PM
Fapout
Mar 10, 2004 03:15 AM
UKjasonm
May 20, 2002 08:15 AM
