1st Differential Fluid Change on an AP2
Old 09-24-2007, 09:34 AM
s2k_redhead's Avatar
Default 1st Differential Fluid Change on an AP2
I did a search but couldn't find a definitive answer to this question. Are people changing their diff fluid early for AP2's just like we did for AP1's?
I changed my AP1 at 6,000 miles (after arguing with the mechanic that I really DID want him to replace the fluid so early). He was shocked and amazed and how sludgey and dirty the fluid was. I remember others had had similar experiences.
I'm planning to do the same with my new AP2, but was wondering if others have had a similar experience (super dirty fluid after just a few thousand miles).
Old 09-24-2007, 10:28 AM
addisonc's Avatar
Yah, I changed the differential oil on my 1st oil change (7500 miles). It is pretty easy to do yourself if you purchase a hand pump. A bottle of Mobile 1 75w90 is only $11, cheaper than an engine oil change.
Just do as often as you like.
Old 09-24-2007, 10:39 AM
daktruckie99's Avatar
Ahh, the wonderful smell of filthy diff oil.
Old 09-24-2007, 10:47 AM
s2k dre's Avatar
thats weird, i first changed my diff fluid at 36k and it was really clean.
Old 09-24-2007, 11:54 AM
I'll be interested to see how it comes out. It's going to be awhile, though. I still haven't got through the break-in period. Oh the pain of not being able to VTEC!
Old 09-24-2007, 11:58 AM
tim62's Avatar
Hi,
Which hand pump did you use and where did you buy it?
Thanks,
Tim
Old 09-25-2007, 06:41 AM
vtec9's Avatar
Impossible. The OEM fluid is dark, dirty, and smells like shit. If it was clean and looked like normal oil, then someone changed it before you.
Old 09-25-2007, 01:00 PM
CosmosMpower's Avatar
It's the same, you need a 23MM socket and 22MM wrench. You can't reach the fill bolt with a socket since there's a brace in the way. We change tranny/diff fluid every 15K since the car is autocrossed and have been using Mobil 1 75W90 for 104K with no issues *knock on wood*
I bought a pump at a local NAPA, it screws onto some bottles of fluid that I used before (Amsoil MTF) and works great.
Old 09-25-2007, 05:57 PM
True. After 5k the oil is disgusting.
Old 09-25-2007, 10:40 PM
Boofster's Avatar
I changed my diff fluid at ~6k miles. It came out flat grey smelling like sulfur. Replaced with LE607. Goes in just fine if you squeeze the bottle. May need an extra quart in hand.
Quick Reply: 1st Differential Fluid Change on an AP2
