2nd and 3rd gear
Old Oct 30, 2008 | 08:19 AM
s2kjunkie's Avatar
Default 2nd and 3rd gear
So I have done a search but most of what i get is from a few years back. Im hoping someone can tell me something new. I just recently bought an 05 with 32,000 miles. Whenever i first start driving at any point during the day no matter if first drive of the day or not, 2nd and 3rd gear are either hard to engage or they almost grind. I just changed the trans fluid last week with honda stuff hoping that would solve the issue but its hasn't. Now i have read several posts saying that this is pretty normal but does that mean for an 05 or for all s2000's. Surely the 08's dan't have the same issue. Have they updated the synchros or anything to remedy the problem. If so, can't i have the updated parts put in to fix the problem.
Old Oct 30, 2008 | 02:15 PM
wisdom's Avatar
I dont' think it worth it to just change the 2nd and 3rd gear synchros. You might be better off with a new/used transmission.
Maybe the previous owner screwed up shifting from 2nd to 3rd.
Old Oct 30, 2008 | 02:18 PM
s2kobsession's Avatar
it shouldn't grind, but it sure doesn't slide in like cutting butter with a warm knife (until the tranny fluid is up teo temp).
If it's still grinding or notchy when everything is up to temp, you have a problem. But s2k transmissions in general aren't 'normal' as they are direct link to the tranny
Old Oct 30, 2008 | 07:05 PM
chuhsi's Avatar
change the clutch fluid?
Old Oct 31, 2008 | 09:58 AM
s2kjunkie's Avatar
Once it's up to temp it is smoother but not always. It's just sorta random from that point.
Old Oct 31, 2008 | 10:45 AM
EVAN&MONICA's Avatar
sounds normal
Old Nov 1, 2008 | 10:31 AM
docholiday8384's Avatar
s2kjunkie, check out this tsb. it says it applies to 2nd gear / my2000, but maybe this can get you started.
TSB 00-055 / Grinding When Shifting into 2nd Gear / MY 2000
empire
Sep 19, 2022 08:02 AM
triforresttri
Jul 19, 2011 02:25 PM
Atb117
May 5, 2009 02:43 PM
TheMightyS2K
Jan 6, 2006 08:17 AM
searchfordeal
Sep 17, 2003 09:49 PM
