2nd gear problem
Old May 18, 2005 | 10:51 AM
Anrosphynx's Avatar
Default 2nd gear problem
I have searched the board for a similar problem, but most seem to be problems engaging second gear. ie-the 1-2 shift. Mine is not this problem.
Essentially, I have no problems switching gears, but while in 2nd gear, it makes a constant "grinding" noise. When I switch to 3rd gear, no noise. 1st gear, no noise, but second gear has a constant rubbing noise during acceleration. Almost like the 2nd gear spring is out of place and rubbing up against something. (sorry, transmission illiterate)
Any ideas what this might be?
Your responses would be greatly appreciated.
Thanks
Old May 19, 2005 | 11:04 AM
Anrosphynx's Avatar
nobody?
Old May 19, 2005 | 03:49 PM
oakfloor's Avatar
check your transmission fluid level, change it out if its old, have a sample of the oil analyzed. is still under warranty? have a mechanic listen to it. good luck
Old Oct 3, 2007 | 03:34 PM
07RioS2k's Avatar
Did you ever find out what your problem was? This just started happening in my car today the same way you described
blackv3ngenc
Sep 9, 2014 09:54 AM
Sundance
Jul 16, 2004 09:12 AM
drchiropharm
Oct 23, 2001 11:32 AM
MarkS2K
May 8, 2001 05:41 PM
