4.77's
Old Nov 30, 2006 | 03:09 AM
freshs2k's Avatar
Default 4.77's
i have the kia cryotreated 4.77's installed on my05 there not richmond but i followed the richmond recomended cycle of drive 10 miles wait.. drive again.. wait. so can i get on it now? or should i wait a week change out the diff oil and then "test drive it"
also: i saw this on ricks2k.com
Note: Use only Honda specs for all bolts. Only use this document for R&P contact pattern info only. Backlash should be set to .008. OEM Settings should not be used and will damage the gears. Improper installation will void the warranty.
^ is that just for richmond gear sets only? i had a place called transmission specialist install my gears. im assuming they used factory specs for everything. There isn't any noise, grinding, or bearing noise just quiet as can be.
Old Nov 30, 2006 | 03:27 AM
Honda_Mad's Avatar
The 4.77 gears uses the same Specs as the OEM gears set
S2K Tuning
UK & Ireland Traders Forum
37
Mar 11, 2013 11:37 AM
SpRuCe
Aug 31, 2010 06:42 PM
EK9MAX
Nov 11, 2006 04:40 PM
Wisconsin S2k
Apr 4, 2005 03:39 PM
biker1
Aug 11, 2004 03:06 PM
