8000K bulb replacement
Old Jan 8, 2006 | 03:07 PM
  #51
SoCalIsMyLife's Avatar
My first attempt at playing around with a projector from a broken MY00 Housing. I'm using a spring as a spacer so that I can adjust the cutoff shield and keep it firmly in place all the time.
You can't really see it in the photos, but I do notice a blue line after moving the shield back a little.
Old Jan 8, 2006 | 03:28 PM
  #52
YELLOS20003's Avatar
Ive got 10000K, ive had them for about a month now and I love them. I've read all kinds of articles about how visibilty with the 10000K sucks. As far as visibilty, I honestly can barely tell a difference between the stock HID bulb and the 10000K and if visibilty is ever an issue, Heaven forbid, I might just have to move my left hand a little bit and flip the brights on. In my opinion for the difference it is well worth the money. When driving down the interstate, the reflectors and signs look blue, they look much better than 4300K. The stocks look yellow when compared to the 10000K, they are bluest headlights on the road.
10000K next to Sylvania's (supposed to blue) Silverstar's Halogen bulbs
Old Jan 8, 2006 | 04:12 PM
  #53
GranPrix's Avatar
Originally Posted by SoCalIsMyLife,Jan 8 2006, 03:19 PM
This is interesting. Could we just move the cutoff shield closer to the reflector on your projector housings and accomplish the bluer looking cutoff band? Then we'll preserve the light intensity while having the look of bluer HID's.
this is where the washers come in:
you unscrew the sheild from the housing add one washer on each side and re-screw the sheild. go here:
http://www.hidplanet.com/forums/viewtopic....der=asc&start=0
Old Jan 8, 2006 | 04:49 PM
  #54
S2KinVA's Avatar
Apples to Oranges, Halogen vs HID no competition!
Old Jan 8, 2006 | 05:32 PM
  #55
Yeah that's what I did with a projector I had lying around. Except I used a spring around the actual screw itself. Can I mod the headlights without taking them apart? It seems like there's a pretty big hole I can work with on the housing.
Old Jan 8, 2006 | 07:40 PM
  #56
Spec_Ops2087's Avatar
GranPrix,
the link in your post said something about a moded cut off shield. Care to explain more in detail?
Old Jan 9, 2006 | 11:25 AM
  #57
GranPrix's Avatar
thank you, well said. you cannot compare halogen and HID lighting.
Old Jan 9, 2006 | 11:29 AM
  #58
GranPrix's Avatar
this is the only and safest way.
you said you used a spring on the screw? you did this on the s2k projector?
Old Jan 9, 2006 | 11:30 AM
  #59
GranPrix's Avatar
Originally Posted by Spec_Ops2087,Jan 8 2006, 08:40 PM
GranPrix,
I'm wondering, are you able to see the thread?
Old Jan 9, 2006 | 01:37 PM
  #60
O I think I might understand, when you say modded shield you mean with the #8 washers...I thought you actually hacked away at the shield for a second there
