ABS Light on, please help
Old Apr 19, 2012 | 07:31 PM
jsenclosure's Avatar
Default ABS Light on, please help
So the other day i went to change my wheel bearing (front right) and i couldn't get the abs sensor out of the spindle for the life of me so i took the alternative route and broke it, knowing i had a spare one form a 2002 at home. Drove the car home after removing the pink abs 30a fuse, installed the 02 sensor in my 00 which i assumed was the same (parts numbers are the same, just checked) and i still have a light on. The lights been on since saturday and i've driven the car every day since then. I figured it would reset at some point but it doesn't look like it's going away. I did the 4-9 OBD2 jumper and here are the codes i got
11, 12, 15 and 16
How can i reset this light?
Thanks
Old Apr 20, 2012 | 07:43 AM
Switchblade's Avatar
Would like to hear an answer to this as well.....
Old Apr 21, 2012 | 03:40 AM
Bump
Old Apr 21, 2012 | 12:38 PM
Sceanzo's Avatar
All of the codes refer to the Right Front and Right Rear speed sensors..
Codes 11 and 15 will stay until the ABS light is reset. Where as the other two will turn off when the system returns to normal.
Old Apr 23, 2012 | 09:06 AM
so i ordered the fornt and rear pass abs sensors. I'll change them out when i get them and post back here, i expect to see the abs light not on after replacing these
Old Apr 23, 2012 | 01:55 PM
Sceanzo's Avatar
That may fix the issue at hand but it won't turn the ABS light off. Like I said, codes 11 and 15 will cause the light to stay on whether or not the problem is fixed. You will have to reset the ABS light after you replace the sensors to clear all the codes.
If BOTH Codes are on like you say. I am guessing a wiring problem.
Old Apr 23, 2012 | 02:37 PM
How do I reset it? I thought I read it should automatically reset itself.
Old Apr 23, 2012 | 06:51 PM
Sceanzo's Avatar
Most codes will go off and the light will reset itself after it performs its self diagnosis. However, some will not as far as I know.
Now for resetting the light. I don't really know how to do it without a honda scanner. Maybe just unplugging the battery for 5 mins
EDIT: Here ya go playboy
https://www.s2ki.com/s2000/index.php...&t=674428&st=0
jsenclosure
Apr 19, 2012 04:20 PM
RedAP2S2K
May 17, 2009 02:56 PM
Costas
Oct 14, 2006 10:31 PM
TrackStar
Feb 4, 2005 06:37 AM
ImportSport
Apr 7, 2004 11:12 AM
