AC issues?
Old Feb 25, 2008 | 10:44 PM
Mystiqueskillz's Avatar
Default AC issues?
I have a 2007 S2000 with 7200 miles and I noticed that whenever I turn on the AC, it makes a clunking/click noise. I first noticed it when I turned on the car and the AC was on from the last drive, so then I turned off the AC and then I turned it back on again and it made that noise again. So throughout the night I turned it on and off a couple times and Im still getting the noise. I never noticed it before, but is it normal or not?
Old Feb 26, 2008 | 09:13 AM
C U AT 9K's Avatar
Is it when you hit the AC button or when you turn the fans on? Maybe something is hitting the fan? A hose or something?
Old Feb 26, 2008 | 09:33 AM
vtec9's Avatar
I think that's happened to me a few times. When I hit the AC button, a hear a clunk. I never paid much attention to it since it seems to go away. My car is 8 years old and the AC still works, and the car hasn't blowed up, so I'll let it slide.
Old Feb 26, 2008 | 10:31 AM
The fans are already on, its just when I press the AC button to turn it on, I hear the clunk/click. I never noticed it until last night.
Old Feb 26, 2008 | 12:23 PM
jzz30's Avatar
that noise is probably the ac clutch. nothing to worryabout
Old Feb 26, 2008 | 05:00 PM
S-Turn AP1's Avatar
Sounds like your hearing the A/C clutch engage , they ofter make a click on snap sound when they engage. If you notice the noise geting louder and louder take it to the dealer.
The worst that could happen would be NO A/C , it shouldn't damage anything else.
Old Feb 26, 2008 | 05:09 PM
ATOice's Avatar
Thanks S-Turn/jzz..It has happenned once since I have owned it, but that's why I always drive with the top down.
Old Feb 26, 2008 | 06:02 PM
Slows2k's Avatar
The refrigerant is the AC system reverts back to a liquid after sitting overnight and it settles in the lowest part of the AC system. The Compressor is the lowest part.
When you 1st turn on the AC or defrost you will hear a louder "thunk" when the compressor is engaged with liquid refrigerant inside.
The compressors clutch will normally loudly click when it is engaged.
Old Feb 26, 2008 | 11:15 PM
Does that mean after continuous use within the day, the clunk will go away until I don't use it anymore and if I turn it on two days later, I will get the clunk noise again?
Old Feb 27, 2008 | 03:46 AM
Slows2k's Avatar
yup.
quaa
15
Sep 18, 2013 01:51 PM
tags
Oct 19, 2011 09:38 AM
slowsilvers2k
Feb 24, 2011 07:37 AM
mrfrieze
Oct 31, 2006 04:46 PM
slimjim43
Oct 27, 2003 12:50 PM
