Acceleration vibration
Old Jul 13, 2011 | 03:36 PM
ap1 George's Avatar
Default Acceleration vibration
I got this vibration on my car (02 ap1) when I accelerate I don't know what it is anymore! It's really making me sad. My car is lowered on buddyclub n+ which I have installed axle spacers to stop the vibration then It came back about half a year after lowering it.
Things I have installed/replaced
Axle spacers
New Axles
Propeller shaft
New outer tie rod ends
Any ideas/input will be appreciated.
Old Jul 13, 2011 | 03:52 PM
dsthez's Avatar
hmmmm hard to say youve done all the obvious stuff, bent driveshaf of bad diff?
Old Jul 13, 2011 | 07:26 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Spacers are crap.
Are the replacement axles Honda or aftermarket?
Old Jul 13, 2011 | 07:27 PM
Billman250's Avatar
Top Answer: 1
spacers mask the problem for a short time, then it returns.
ALXE BUCKET SWAP is the cure. Repalcement axles that are not honda dont run at the precision that the oem axles do.
Old Jul 13, 2011 | 11:00 PM
ap1 George's Avatar
So the problem points back to my axles? I replaced the OEM ones cuz they were bad then I ordered a pair from NAPA auto parts.
Old Jul 14, 2011 | 03:33 AM
Billman250's Avatar
Top Answer: 1
Thats your problem.
Pull the buckets off the stock axles and check them for pits. if so, swap the buckets side to side and put them back in.
LEAVE THE SPACERS out.
Old Jul 14, 2011 | 08:09 AM
ap1 George's Avatar
Thats your problem.
I've heard of axles pitting but what is it really? I'm not sure what pitting means exactly.
Old Jul 18, 2011 | 01:25 PM
ronnuke's Avatar
https://www.s2ki.com/s2000/gallery/i...64-cv-pitting/
Old Jul 18, 2011 | 08:50 PM
00S2K01S4's Avatar
Do you have another set of wheels? I had similar problem. Changing rear tires fixed problem.
Old Jul 19, 2011 | 11:18 AM
ap1 George's Avatar
I have a set of OEM axles I can fix. if not then ill change the wheels see if it makes a difference. thanks
Dig8r
Oct 23, 2014 10:47 AM
Jrse7en
May 2, 2011 08:37 AM
Nick.
Mar 10, 2010 12:33 PM
Paper Lawyer
Aug 10, 2008 11:53 AM
Rain
Jan 25, 2008 05:39 PM
