acessory socket not working?
Old Jul 6, 2006 | 12:45 PM
jert534's Avatar
Default acessory socket not working?
So for some reason my accessory socket isnt working, Ive tried 2 different sockets and get no voltage to them, but if I put my voltmeter into the contact and the other to a ground I get 12.45 volts, I checked the fuse and it's good, what else could it be?
Old Jul 6, 2006 | 02:11 PM
SheDrivesIt's Avatar
If you check between the center contact and ground and you get 12+ volts then your fuse and positive side wiring is good. Note that the outlet is mounted into plastic and that would mean that there is both a hot wire and a ground wire to the socket. My bet is that you do not have 12 volts from the center contact to the socket body because the negative or ground side wire is disconnected at some point.
Old Jul 6, 2006 | 04:31 PM
jert534's Avatar
Weird, was playing around with the connection and socket, I was getting voltage on the wiring but when I put the socket on there was no voltage, after about 5 mins I tried it again and I got hot and ground with the socket on and now it's working fine...
geared
Aug 25, 2012 05:49 PM
liquidgsr
Dec 6, 2011 05:16 AM
robs2g1
Aug 26, 2011 06:23 PM
Blurter
May 23, 2005 01:38 AM
Fiend
May 23, 2001 06:38 PM
