Adding DRLs (Daytime Running Lights) to a US-spec S2000
Originally Posted by GaryRudolph,Nov 5 2004, 01:40 AM
Just curious why you went down this route instead of installing the Honda DRL controller and changing the US wiring to match the CA wiring? Was the cost significantly more?
semi related. is there someway to rewire the oem so that the low beams doesn't come on on the flash to pass?
also the low beam doesn't shut off if i have them on already and want the high beams(not flash to pass...
Originally Posted by S2K EH,Nov 5 2004, 12:52 AM
Sorry to be pedantic - but anything different if I want to do this to my MY04 ?? Is wiring different or anything ?? This is something I have wanted for a while now....
If you pull the lead that goes to the 'ignition source' lead under the dash, then the DRLs will go off (everything else will still operate normally). If you put a switch inline with that, then you have the ability to toggle the DRL behaviour.
