Adding DRLs (Daytime Running Lights) to a US-spec S2000
Old Apr 30, 2010 | 08:35 AM
  #41
inactiveuser1114's Avatar
Originally Posted by Dressed2Kill,Nov 30 2009, 10:22 AM
I am going to use this to make some high beam fog light.
This is why I've been wanting to do it too, but $73 bucks for just the relay doesn't really cut it
Old Apr 30, 2010 | 08:56 AM
  #42
CapoArgentino's Avatar
Banned
I bet I can run a heavy duty resistor from Accessory 12V to the high beam lamps. The resistor would limit the voltage so they will light up 60% to achieve the DRL illumination. I'll look into that and let you guys know.
Old Apr 30, 2010 | 09:12 AM
  #43
That sounds good man, what might seem tricky probably is being able to switch from 60% light to 100% when you turn the Highs on ... maybe integrating the resistor with a standard 12v relay? this would definitely be a cheaper option (la cosa esta mala lol) but keep us posted with what you come up with! thanks
Old Apr 30, 2010 | 09:23 AM
  #44
Banned
^^ Tell me about it
Yeah I'll take a look at the wiring diagrams. It cant be that hard.
Any Canadian owners want to let us know the behaviour of the OEM DRL under all conditions? (i:e. While engine is running, while high beams are switched on, during the night, etc etc) So I can emulate as close to OEM function as possible.
Thanks,
Old May 2, 2010 | 12:19 PM
  #45
wisdom's Avatar
Bump for updates.
Old May 2, 2010 | 02:55 PM
  #46
wisdom's Avatar
I found this on another forum. I think this may be the solution. This is the original thread, but i don't like this method because a switch is needed.
http://www.8thcivic.com/forums/lighting/53...-low-beams.html
But this is the follow up, and i'll be using this method.
http://www.8thcivic.com/forums/lighting/16...tml#post6119518
Thoughts?
jezzder
May 7, 2007 03:05 PM
S2KXTC
Jan 13, 2003 11:19 AM
tantheman
May 30, 2002 06:07 PM
airgate
Mar 16, 2002 05:57 AM
