Adjust this?
Old Mar 25, 2015 | 03:04 PM
S2k_razy's Avatar
Default Adjust this?
How could I adjust my timing chain? I know where all the marks are suppose to be aligned but I need to know how to get the chain around. Took my tct off, got some slack but can't seem to move my chain around to get it aligned.
Old Mar 25, 2015 | 05:19 PM
cleenyc99's Avatar
how did it come out of alignment? the marks on the chain will not line up again once the engine is spun if that's your thought
Old Mar 25, 2015 | 07:05 PM
S2k_razy's Avatar
Ik for sure it's off a tooth or two. Just need to know how to align it.
Old Mar 26, 2015 | 04:38 AM
Slowcrash_101's Avatar
Remove TCT, then the cams, carefully remove the cam wheel bolt, carefully, without dropping anything. That will give you enough slack to reposition the chain. Conversely you can save a little time by making sure piston 1 is at tdc by aligning the crank pulley mark, then remove the camshaft that's off and reposition it.
S2k_razy
Mar 15, 2015 03:30 PM
Sideways
Sep 27, 2011 01:20 PM
shiesty
Sep 9, 2007 08:10 PM
Atheist
Aug 17, 2007 10:04 PM
mxt_77
Nov 11, 2004 08:23 AM
