adjusting the clutch pedal level
hi, i tried to adjust the clutch pedal level because the depth was too shallow.(not deep enough) but the lug wouldnt unscrew and when i tried to unscrew, i was scared because that thing goes into the master cylinder thing was moving along with it also.....am i doing something wrong? plz someone if pics, or details help me out.
thanks,
John.
thanks,
John.
Sorry, no pics.
That rod threads into the bracket at the top of the clutch pedal. Near the end of that rod is a lock nut that snugs up against the front side of the bracket. You should be able to back that nut away from the bracket and then spin it freely down the rod shaft. Then you can turn the rod to adjust the clutch friction point. Spin the nut back against the bracket to lock it down.
What isn't "deep enough"? Are you wanting to adjust the engagement point, or the pedal stroke? If you want to increase the pedal stroke, you do that by raising / lowering the clutch switch that acts as a bump stop for the pedal assembly.
Originally Posted by nureulwihaesuh,Sep 10 2004, 09:25 PM
What i mean by shallow is that there is too much free space on the clutch pedal. help guys
Sorry, but even this description doesn't make any sense. It's also obvious that my posted directions for adjusting the pedal isn't what you're looking for. You need to be more precise in telling us what your issue is.
Originally Posted by TurboVtk,Sep 12 2004, 02:11 PM
i think he wants to change the engagement point. because is too high.
Since he asked for "HELP" 40 minutes after I posted a suggestion, I just assumed that this was not what he's looking for.
Defender
Oct 14, 2002 06:26 AM
