clutch pedal adjustment?
Old Jun 22, 2007 | 06:45 AM
02s2k01s4's Avatar
Default clutch pedal adjustment?
do our cars have clutch pedal adjustments! and if so how hard is to do or where could i get instrutions to do it? - tommy
Old Jun 22, 2007 | 06:55 AM
stphotographer's Avatar
Do a search!
A majority of the time the clutch does not need adjustment. Try bleeding the system first. Not adjusting the clutch pedal correct may lead to premature wear.
Look behind your clutch pedal for the rod that goes into the firewall. The part closest to the firewall has a lock nut. Loosen the nut and turn the rod in 1/2 turn increments til the feeling is right.
Old Jun 22, 2007 | 07:48 AM
02s2k01s4's Avatar
i just tried to lossen the nut you were talking about and cant get it loose. but on the other hand how do you bleed the clutch system? the search function has not brought me any usfull info
Old Jun 22, 2007 | 08:38 AM
https://www.s2ki.com/forums/index.php?showtopic=108435
Old Jun 22, 2007 | 07:11 PM
jyeung528's Avatar
there are two adjustments you can make,
1 is the clutch pedal stop point, and the 2nd is the push rod.
you should really know what you're doing before you adjust either.
zakazak
Sep 27, 2013 07:34 AM
Dredd123
Feb 26, 2013 06:46 AM
Sceanzo
Oct 3, 2012 07:03 PM
nj-s2k-rob
Apr 4, 2008 08:00 AM
Gh0ztt
Feb 18, 2008 06:43 PM
