aem cai cel light
Old Jul 20, 2006 | 02:46 PM
outcrnru's Avatar
Default aem cai cel light
Ok well I installed the AEM intake a couple days ago and everything worked great, parked it that night, no problems
I started the car the next morning and the cell light came on right away. Still runs normal, goes into vtec and what not, just not sure why the light came on.
Does anyone have any suggestions? I did not disconnect the battery when i installed the intake, do i need to reset the ECU? Thanks for any help you can give me
Old Jul 20, 2006 | 03:08 PM
xviper's Avatar
You do not have to reset the ECU when you put a mod on. It'll learn on its own in due time. But now that you have one, you might want to pull the code first to see what it really is.
I'm thinking you messed up the vacuum lines when you did the CAI and the CEL will read P0411. Follow the steps and pictures here and trace everything.
https://www.s2ki.com/forums/index.php?showtopic=105368
Old Jul 20, 2006 | 04:08 PM
outcrnru's Avatar
cool, i routed evrything the right way except the check valve isnt in place, would this cause the problem?
thanks
Old Jul 20, 2006 | 04:58 PM
xviper's Avatar
thanks
Absolutely. That check valve ensures that vacuum (or pressure) goes only one way. Not only does it have to be in place but it must be installed in the correct direction. Why did you remove it?
Old Jul 20, 2006 | 07:36 PM
Slows2k's Avatar
Put the check valve back and the CEL will go away
Old Jul 20, 2006 | 07:51 PM
outcrnru's Avatar
haha didnt think id need it, i had no instructions, my noob fault thanks guys
doinou88
Feb 10, 2008 06:55 AM
woo
Jan 18, 2006 08:36 AM
USCstudent
Dec 20, 2004 04:53 PM
ItalianBucwheat
Jul 14, 2002 03:40 PM
S2K Power
Jun 16, 2002 05:46 PM
