AEM V2 Install help
Old Oct 24, 2004 | 04:49 PM
YogiCA's Avatar
Default AEM V2 Install help
Hi all,
Almost finished with the v2 install, took me a good 5 hours so far, and just need to put the wheel back on and figure out the hosing.
I basically cant figure out where the upper and lower hosing needs to go. I looked at the instructions and it gets a little vague. I've posted pics, please help me out - I need the car for work tomorrow :/
Thanks!
Old Oct 24, 2004 | 04:54 PM
azndrunkyoon's Avatar
the upper goes the the "and this one?"
and the lower goes to "what do i do with this"
it's on page 4 of your install directions
the picture showing exactly where it goes is on the bottom right. see where his hand it? with the white thing. that is where the upper goes to and the lower go to the part with the other small hose you disconnected
Old Oct 24, 2004 | 04:58 PM
just lok where it sayd supplied lines. the picture is VERY clear.
Old Oct 24, 2004 | 06:02 PM
YogiCA's Avatar
Thanks guys! SO what do I do with the other "old" hoses.. it looks like the run down into something behind the radiator.... should i just pull them out?
Old Oct 24, 2004 | 06:07 PM
YogiCA's Avatar
Alright, so I did like you mentioned azndrunkyoon. Its dark outside now, I'll take a look at the instructions again to see if it mentions anything about the old hosing.
BTW, the upper and lower are little bit loose when i plugged them in, should I grab some rings from the autostore?
Im such a newb at this, but you gotta start somewhere.. right?
Old Oct 24, 2004 | 06:16 PM
YogiCA's Avatar
ok, the upper hooks up with the other hose with the white cap. this leaves one hose doing nothing though. the hose down to the right, coming from some black box behind the radiator. Any ideas?
Old Oct 24, 2004 | 06:37 PM
YogiCA's Avatar
Does this look right guys? I'll be taking it for a run tonight, i just want to make sure i got it right before i start her.. dont want to break something :/
btw, one of the hoses is still kinda lose, I think its the lower vacuum hose that a little lose. I might have to buy a little clamp for them.
Old Oct 25, 2004 | 10:24 AM
xviper's Avatar
Trace all your hoses and check valve direction using this:
https://www.s2ki.com/forums/index.php?showtopic=105368
It's really all you need to know.
Old Oct 25, 2004 | 10:48 AM
YogiCA's Avatar
Cool! Thanks man. Looks like I got it now. Took it to work this morning and loved the new VTEC experience. Fingers crossed that I don't have any problems with it and the rain now.
Old Oct 25, 2004 | 03:17 PM
clamps aren't required. if they were aem would have put them in.
i just put some spit on the outer side and slid on the hoses because spits give alittle grip
WDPhead
Aug 8, 2011 07:02 PM
GT_NFR
Feb 11, 2008 07:00 AM
imagine32000
South Florida
Dec 15, 2005 06:38 AM
MY04NFRS2000
Oct 6, 2005 04:36 AM
robs04s2k
Jun 24, 2004 06:56 PM
