Air Pump Melted. Options?
Old Oct 27, 2010 | 12:08 AM
lordbyron's Avatar
Unhappy Air Pump Melted. Options?
Long story short. Heard a louder than usual humming / whining sound. CEL came on, went to pepboys they found it throwing a P0411. Looked it up here on s2ki, found the air pump threads. I pulled MY bumper and found this:
I need help with my options:
-I have read about the delete kit which isn't going to be released anymore.
-Buy a new one $500 / used one $100-250 (with the possibility of the same problem down the road)
-I have read that if you get an AEM EMS its possible to bypass the system. Not cheap.
-Can a VFAC II bypass the air pump?
Running the car with the CEL on is not an option. Do you guys have any suggestions / advice? Thanks in advance.
Old Oct 27, 2010 | 01:22 AM
Neutered Sputniks's Avatar
Take it to Honda. There's a TSB for this
ETA: http://ww2.justanswer.com/uploads/HondaCB7..._200503_411.pdf
Old Oct 27, 2010 | 09:02 AM
Slows2k's Avatar
The Tsb is not a warranty extension.
Old Oct 27, 2010 | 09:26 AM
I was under the impression that the Air Pump is covered under the emissions warranty. Perhaps I was mistaken.
Either way, there's a chance it will be good-willed. The OP has no reason to not contact Honda.
Old Oct 27, 2010 | 01:14 PM
lordbyron's Avatar
the "s" is now at the dealers.. its waiting for the district managers approval.
Old Oct 27, 2010 | 01:16 PM
lordbyron's Avatar
thank you for this
Old Oct 27, 2010 | 01:58 PM
suzuka-blue-s2k's Avatar
The best way would to just buy a used air pump from someone on here. I had to go through this also.
There is no real way around the air pump CEL unless you replace the pump, or get an EMS. A VAFC cannot do anything like that. I found my air pump on here I think less than $100 shipped for just the pump. Solved all the issues and got it done with for now.
Old Oct 27, 2010 | 07:16 PM
lordbyron's Avatar
https://www.s2ki.com/forums/index.ph...&f=16&t=826005
Old Oct 30, 2010 | 08:36 AM
phonedrn8's Avatar
find one used for less replace in 30 min all ok
SHIFTAT9
Aug 25, 2011 03:37 PM
hshiznit
Jun 28, 2010 09:47 AM
jyeung528
Apr 24, 2007 03:58 PM
Venomous S
19
Mar 14, 2006 09:31 PM
