Air Pump Question
Old Jan 2, 2003 | 11:49 AM
Prolene's Avatar
Default Air Pump Question
Interesting that the air pump will allow flow either way when it is turned off (I bench tested it). Anyone know if there is a valve or valves downstream to prevent exhaust gasses from flowing into the intake, or is the pump on all the time?
Old Jan 2, 2003 | 12:23 PM
cdelena's Avatar
There is an air control valve back by the firewall.
Old Jan 2, 2003 | 12:41 PM
Gernby's Avatar
Former Sponsor
Is the pump necessary, aside from emissions? It seems like it would be a good candidate for weight reduction...
Old Jan 2, 2003 | 01:36 PM
cdelena's Avatar
[QUOTE]Originally posted by gernby
[B]Is the pump necessary, aside from emissions?
Old Jan 2, 2003 | 01:50 PM
Gernby's Avatar
Former Sponsor
Originally posted by cdelena
Even if you don't care about the emissions you need the pump to avoid a MIL and it is hard to monitor for other problems if the lamp is always lit.. and in most states you need to avoid a MIL to pass inspection.
I am concerned about emissions to an extent, but not necessarily enough to worry about LEV compliance in a state that doesn't require it. Looking at the Check Engine Light would bother me.
Old Jan 2, 2003 | 08:32 PM
Prolene's Avatar
Thanks, cdelena! I tried running the car without the air pump for a bit, and as expected, the Mugen ecu gives no mil (cel). I don't recall ever hearing the pump as I did preMugen ecu as well, so perhaps the new ecu disables the pump.
s2konroids
Dec 25, 2011 07:08 AM
gravitykills
Aug 28, 2008 06:04 PM
s2000honduras
Dec 18, 2005 11:09 AM
