Air vacuum valve
So I recently heard a noise coming from my engine bay that sounded like an air leak. I pin pointed it to the little air vacuum bypass valve thing that bolts to the air box. It has 2 vacuum hoses coming off of it and a plug. Part number is denso 084860-7630. What I need to know is where can I get one or does anyone have one they want to sell?
I have one for sale if you want it. PM me.
(assuming you are talking about part #2 in this diagram) http://www.hondaautomotiveparts.com/...y5=VACUUM+TANK
Have owned my S2000 for the past 4 years and have done tons of research and completed a few wire tucks on Hondas and especially the S2Ks. The VALVE ASSY., BYPASS CONTROL SOLENOID that is listed on the previous posting is the OEM part for the S2000. However, through research, I have found the same (similar) valve that will work for a much lower cost. If you search this forum for the valve you will locate my post that list the replacement valves. The valve I have used and has worked flawlessly since installed is the one found on a 94 Accord (mounted on the firewall) that assist the rear motor mount. I have found several of these in local car lots (junk yards) for pennies on the dollar. ($5.00 to be exact).
So to save yourself a Benjamin, research this forum. Who knows, you may find other DIY fixes that you may need for your ride.
EagleDon
EagleDon
bumble_bee
Jan 28, 2010 07:15 PM
