Airbag light Stuck on?
Old Nov 15, 2007 | 09:40 AM
lawerence's Avatar
Default Airbag light Stuck on?
I just switched my sparco steering wheel out for a stocker, everything is wired correctly but the airbag light is still on (solid). Is there a simple way to get rid of this or do I have to take it to a Honda dealer?
Old Nov 15, 2007 | 10:36 AM
NVMY4N's Avatar
not sure..
you could try pulling the backup fuse to clear the ECU....but Im not sure if they are connected.
There may be a fuse for specifically that, but Im unsure. that would be worth researching.
Old Nov 15, 2007 | 11:29 AM
JawKnee's Avatar
There's a special procedure to reset it. I'll post it when I get home if you have not figured it out by then.
Old Nov 15, 2007 | 11:34 AM
lawerence's Avatar
Thanks much, appreciate it!!!
I'm currently digging through google nothing seems to be working so far.
Old Nov 15, 2007 | 02:31 PM
S2KPUDDYDAD's Avatar
The SRS is it's own system not part of the cars ECU. Honda has a little jump tool to reset the SRS system. The jump tool is $14.00 from Honda parts that is if they will sell it to you. Some have used a paperclip or wire to jump the system but, I will not suggest that.
Old Nov 15, 2007 | 03:59 PM
Slows2k's Avatar
The SRS unit won't clear a DTC when power is removed from it.
Old Nov 15, 2007 | 05:31 PM
JawKnee's Avatar
PM your # and I'll walk you through the process; sorry just don't feel like typing up the procedure.
Do note that this method isn't recommended by the Service Manual/Honda, but I personally did it.
Old Nov 16, 2007 | 10:04 AM
dalink's Avatar
Evasive has/sells the SRS relay set up with the Nardi steering wheel.
http://www.evasivemotorsports.com/merchant...=QR-COMBO-S2000
Please check it.
S2005x
Oct 8, 2025 02:06 PM
driftnaaasty
Jun 30, 2013 03:37 PM
S2KVITO
Aug 9, 2010 08:03 AM
levitronix
Nov 13, 2008 02:02 AM
Rusler Firbrand
Jul 14, 2004 10:06 AM
