Alignment Suggestions for my Koni/GC Setup?
Old Nov 22, 2008 | 11:39 PM
Driv300mph's Avatar
Unhappy Alignment Suggestions for my Koni/GC Setup?
Hey all... seeing if anyone has any input to give here...
Recently installed a Koni/GC setup... 450 front/500 rear springs
I think the springs I got are a little too stiff to get use out of the adjustable shocks... but perhaps that's only because I'm running street tires. Seems that if I set the shocks to be anything over full-soft that it's just too stiff to do any good at all.
So, I'm running full soft on the Konis and am lowered with about a 1/2" fender gap.
Being that my springs are so stiff, would I be OK sticking with the UK alignment specs? Or should I get less than -2.0 camber in the rear?
Also wondering on the caster -- UK Spec says 6.45deg, but again, being so stiff, would something like 6deg or 5.75deg caster be more appropriate?
Thanks to anyone who can help!
Troy
Old Nov 23, 2008 | 04:09 AM
negcamber's Avatar
What size wheels & tires are you running? What things have you done that have added or subtracted weight to the car (subwoofer, single exhaust, etc)?
Old Nov 23, 2008 | 10:35 AM
Driv300mph's Avatar
Stock AP2V1 Wheels with stock 215/245 RE050's
Took out tool box & spare tire... that's it, and will soon have a spugen dual oval exhaust (probably not much weight savings there though)
jojipoji
13
Apr 5, 2012 01:42 PM
kleecker
Mar 2, 2006 03:39 AM
xda2000
Oct 11, 2004 08:16 PM
n'C Honda
Aug 15, 2004 01:42 PM
speed4tu
Jan 16, 2003 07:32 AM
