Alternative source for rear diff crush washer?
Old May 9, 2017 | 06:57 PM
airlyss's Avatar
Default Alternative source for rear diff crush washer?
i just picked up an '02 S and have been replacing all of the fluids to get it ready to go for summer. The last thing left is the rear diff, which I plan to tackle this weekend. I dropped by the local dealer yesterday to pick up crush washers, but they only had the washer for the drain bolt (out of stock on fill bolt). I'm trying to decide whether to:
1) order online (anywhere cost effective to do this?)
2) find a local store (NAPA or autozone) that has something that might fit
3) reuse the crush washer on the fill bolt (not ideal, but I'm thinking it's not as bad as reusing the drain bolt washer)
Any advice would be appreciated!
Old May 9, 2017 | 07:04 PM
s2000maniac's Avatar
You can order another drain bolt and use that as fill bolt as it has the same thread pattern. Then you can use the same crush washers and plus you get two magnetic bolts that will pick up more metal shavings. Also you can possibly re-use the crusher just flip the other side of it.
Old May 9, 2017 | 08:32 PM
s2cho's Avatar
flip the washer and reuse it or order it from majestic honda and put it off for a week. The fill bolt isnt really that important, the drain bolt constantly has fluid on it
https://www.hondaautomotiveparts.com...artsSearch.jsp
Old May 10, 2017 | 05:45 AM
HotMess's Avatar
In a pinch, you can reuse the crush washer. BUT, i would suggest if you go this way that you take a propane torch to it until it turns red hot for a few seconds. That'll soften it like a new one, enough to let it seal reliably again. I've done it several times, usually when my local dealer gives me the wrong washer
Old May 10, 2017 | 06:34 AM
cdelena's Avatar
I simply reuse them. Have never seen a problem as long as you don't over torque the bolt.
Old May 10, 2017 | 07:22 AM
Car Analogy's Avatar
For the fill bolt? Even I think that is overkill. Just reuse the old one. I would be shocked if a single drop of fluid escapes from reusing fill bolt washer.
Now, I wouldn't reuse fill bolt washers forever, but certainly can reuse them with no worries.
Old May 10, 2017 | 07:45 AM
Langelo DeMysterioso's Avatar
The dealer can order it and it would be there in a day or two.
Old May 10, 2017 | 08:29 AM
airlyss's Avatar
Thanks guys - I ended up ordering some from Bernardi Parts! Probably would have been fine reusing, but figure I'd do it right if I'm going to spend time doing it
Old May 10, 2017 | 01:05 PM
jyeung528's Avatar
i bought some washers from home depot for the drain and the fill bolt and changed them out when i had a chance to buy the oem washers.
freq
Apr 15, 2018 10:55 PM
S2005x
Aug 19, 2016 12:26 PM
booski
Sep 9, 2009 07:31 PM
RGlbk
Jan 5, 2008 02:45 PM
Tugz_S2K
Mar 18, 2004 06:09 AM
