Alternator question
Old Jan 29, 2007 | 03:28 PM
heath389's Avatar
Default Alternator question
Anyone have to replace the alternator? Mine is bad and needs to be replaced. Is it something I can do myself or should I just pay a shop to fix it. .?
Old Jan 29, 2007 | 03:35 PM
milkbubble's Avatar
What symtoms are you having that lead you to want to change your alternator? Have you load tested your battery?
Old Jan 29, 2007 | 04:01 PM
heath389's Avatar
I've put three batteries in the last 12 months
Old Jan 29, 2007 | 04:36 PM
Slows2k's Avatar
You need to have the charging system checked out before guessing at replacing the alternator.
Old Jan 29, 2007 | 04:49 PM
BlownAP's Avatar
If it is your alternator the novice mechanic could do an alternator in 30 mins on an s2k super easy!
Old Jan 29, 2007 | 04:59 PM
heath389's Avatar
Cool thanks for the help
Old Jan 29, 2007 | 05:01 PM
BlownAP's Avatar
remove the intake, removed belt, remove the 2 bolts hold the alternator on,
then remove 1 green plug in the back of the alt. and a ground wire. DONE
Old Jan 29, 2007 | 05:03 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
That's not a ground wire, It's a HOT wire. You are almost guaranteed to short it out with the wrench, unless you disconnect the battery
Old Jan 29, 2007 | 05:04 PM
jzz30's Avatar
the tricky part is getting it back in
Old Jan 29, 2007 | 05:05 PM
BlownAP's Avatar
ouch, well I missed the most important step,
ALWAYS disconnect the battery first!
DOH
08s2000CRbackinblack
Jun 4, 2011 06:04 AM
WeezyBaby
Mar 24, 2010 09:32 AM
REVZ TO9
Apr 2, 2006 09:21 PM
00S2K01S4
Mar 15, 2006 11:25 AM
DaPutster
Jun 27, 2005 03:13 PM
