AMSOIL Engine oil
hahaha...ok good responses! Sorry guys...I should have been more passive in my responses.
One thing about an oil change is how one gets such strong feelings about the success of their oil and filter. I've listened to many guys state "I'm using ____ and I love it!"
What the hell does that mean. How do you obtain pleasure from your oil and filter???
If you're not getting YOUR actual oil analyzed how can you tell the difference between Amsoil, Mobil1, or Advance Auto brand??? During late nights in the garage is your car letting you know it loves your choice of lubricants?
Hopefully this is an acceptable level, as to not come across as confrontational.
I would recommend getting the OEM Honda filter if at all possible. When I had my Integra Type-R, I used the K&N Gold Class filters because although not as good as OEM, they're leaps and bounds better than the Fram.
I got MY02 about 7 weeks ago. I don't know what oil came in it, but the filter looks generic(mostly white w/ blue lettering). As the oil level has dropped I've been adding Castrol Syntec to keep it topped off, & the rate of oil burn-off has decreased. After reading extensively in this forum I've purchased a 2.5 gallon bottle of Amsoil. I'll be changing the oil very soon(this weekend or the next). I've also ordered LE607 for the diff & GMSynchromesh FM for the tranny. They should arrive on my doorstep w/n the next couple of days. As far as oil filters go, I had already purchased a K&N oil filter. I've heard most people say that the OEM is the best. Should I take the K&N back, or is it comparable to the OEM(PCX). I haven't read anything comparing these 2 oil filters(lots of stuff on all other filters though)
tizbad2k: How often do you change your filter? Does a lot of oil fall out when you haven't drained the pan first? Do you think the K&N oil filter is designed for longer oil filter changes?
WVtwisties: Here is a link showing a disection of the Fram and the OEM:
Filter disection
Just in case you wanted to see it for yourself.
Filter disection
Originally Posted by Sideways,Aug 15 2005, 07:42 AM
AMSOIL ATM 10/30 here. I added this stuff and dynoed an additional 120 hp.
I did install a blower at the same time.
Umm, I'm sure most of that extra power came from the oil, and NOT the blower...j/k
Originally Posted by WVtwisties,Aug 14 2005, 02:50 PM
It sounds like the Mobil 1 synthetic oil is acceptable though. I'm sure if enough people see this, in a few days, it will be 'crap oil' too!
Originally Posted by tizbad2k,Aug 15 2005, 10:29 AM
I change the filter around 3k miles. And if you let the car sit overnight, not verymuch oil comes out when you change just the filter.
