Amsoil MTF
Old Feb 4, 2006 | 11:23 PM
i77ac_10's Avatar
Default Amsoil MTF
Hi,
I was looking into Amsoil MTF for my next transmission fluid change. Does anyone have experience w/this oil? From previous posts, it doenst look like too many people have tried it.
I like that Amsoil lists it as a replacement for Honda MTF. However, one thing that bothered me about the Amsoil MTF oil is that its rated at 5W-30, Is that right? Isn't Honda MTF like 75W-80?
Heres the oil I'm looking at:
http://www.amsoil.com/storefront/mtf.aspxh...efront/mtf.aspx
Old Feb 5, 2006 | 12:44 AM
MrChoi's Avatar
honda mtf is 10w-30
Old Feb 5, 2006 | 12:54 AM
Jsmply's Avatar
Originally Posted by i77ac_10,Feb 5 2006, 03:23 AM
Hi,
I believe Honda MTF is 10W30. You are probably thinking about the gear oil used in the rear differential when you were thinking 75W80. The transmission and gear oil are NOT the same thing.
Old Feb 5, 2006 | 08:34 AM
riceburners2001's Avatar
diff oil = 75w-90
im using amsoil TMF in my 01, works good.
Old Feb 5, 2006 | 08:47 AM
i77ac_10's Avatar
Ah ic, gear oil and engine oil are rated differently. I'm not sure what the translation is, but on the Redline site the MTL fluid is rated as a 70W80 GL-4 Gear Oil (SAE 5W30/10W30 engine oil viscosity).
This is sort of confusing. So assuming that Honda MTF is 10W-30, by going w/the Amsoil stuff am running a thinner weight? Is that ok?
Old Feb 5, 2006 | 08:52 AM
i77ac_10's Avatar
Oh, I think they are rated differently because they are tested at different operating temperatures. My from google search: "Gear oil viscosity is measured at 150 F vs. 210 F for motor oil"
Old Feb 5, 2006 | 09:17 AM
S2kracka's Avatar
Gear oil and engine oils are rated differently, a 75W-80 gear oil is ~ equal to a 5W-30 engine oil.
Old Feb 5, 2006 | 09:30 AM
i77ac_10's Avatar
Another note, on Redline's datasheet, they list Redline MTL as a 70W80 gear oil and as a 5W30 motor oil. Heres a table of some of the specs that were published on the Amsoil and Redline websites:
[CODE]
TYPICAL TECHNICAL PROPERTIES
Saki GT
Jan 18, 2010 12:38 PM
Quikie
Jul 2, 2009 12:38 PM
Clutch.
Aug 6, 2008 12:38 PM
Avionics86
Mar 17, 2008 07:15 AM
s2k_suprchrgd
Jul 9, 2005 12:29 PM
