Upper Mid-West S2000 Owners Members from the upper mid-west including Michigan, Illinios, Indiana, and Wisconsin
trans oil change.
Old Jul 2, 2005 | 10:55 AM
s2k_suprchrgd's Avatar
Unhappy trans oil change.
i m changing my trans oil, i just wanna know what kind of oil is the best for my supercharged S2000. thaks, nick
Old Jul 2, 2005 | 02:33 PM
ruexp67's Avatar
Honda MTF. It's the only stock/honda fluid I use. I use Mobil1 for the diff and Castrol GTX for the engine.
Old Jul 2, 2005 | 04:40 PM
Dezoris's Avatar
Everyone has their own preference.
For some drivers, Honda MTF works great. Depends on how you drive and the trans in your car.
Honda MTF did not hold up in my car, within 3000 miles the trans got notchy, and showed signs of slight grinding in second.
After two cycles of Honda fluid, I switche to GM Syncromesh FM.
Never had a problem in heat with notchiness or ever had a grind again.
Some people say Syncromesh did not work more than 6000 miles and that Redline MT90 worked better.
WIthout sounding like a broken record, if your trans feels good, use Honda MTF.
Old Jul 3, 2005 | 01:08 PM
profpin's Avatar
im using redline mt90 and its doin just fine..
Old Jul 3, 2005 | 07:05 PM
Sgt Skidmark's Avatar
I've used Honda MTF and GM Syncromesh.
Both worked very well.
I usually change it every 5k or so. Takes no time at all, so if the car is already jacked up.....yada yada yada
Old Jul 6, 2005 | 12:47 PM
what about using mobil 1 gear oil 75w90?
Old Jul 6, 2005 | 01:01 PM
ruexp67's Avatar
For the TRANS!??? That's way the wrong stuff.
The Mobil1 75w90 is great for the differential, but NOT the transmission.
Old Jul 7, 2005 | 02:43 PM
youngjun91's Avatar
GM Syncromesh FM...is that made by General Motors?!?! Where do I buy it?
Old Jul 7, 2005 | 04:08 PM
Huskergirl's Avatar
My first change I used MTF, the second change which I'm doing Sat. I'm going to use the Synchromesh.
For the diff. I used the Mobile 1 but I'm going to change to the LE 607 Almasol (sp?)
And for brake I used ATE super blue but I'm changing to the gold.
Old Jul 9, 2005 | 12:29 PM
S2kracka's Avatar
I'm very happy with my MTF right now, I may try MT-90 once the warranty is up though since I had great luck with Redline in my DSM.
osidis
Dec 7, 2010 07:31 PM
TRDLiquidSilver
Jun 6, 2008 07:40 AM
i77ac_10
Feb 5, 2006 09:30 AM
S2FLY
Nov 29, 2001 04:37 PM
legalrep
Jun 13, 2001 08:47 AM
