Anti Squeal Compound for Brakes
I just bought some CRC Disc Brake Quiet. It says Not for use with shimmed pads. I purchased some Carbotech Panther AX6 pads which I reckon may squeal. Are shims and anti squeal compounds incompatible or is it just this particular brand?
Thanks for your help.
Honda uses grease on the shim pack. Take a look at the old setup and you will see a VERY thin film. I used crc as well and it didn't help. The Ax6 is a decent pad, but noisy and super dusty.
