Any negative issue with leaving the coolant
Old Sep 12, 2007 | 08:06 PM
ChefJ's Avatar
Default Any negative issue with leaving the coolant
I have a turboed car and since the install I removed the cable to the coolant control valve and left it in the open position. Is there any harm that can be done by this??
Old Sep 13, 2007 | 05:58 AM
Soul Coughing's Avatar
all thats doing is letting the coolant flow through the heater core inside your car. Unless you removed that as well?
When i have the top down and have the heat on but no fan speed, the negative pressure inside the cabin will suck air through the vents. If its on hot, lots of heat will come through, so unless you don't have an issue with that, i wouldnt see why you would have a problem...
If anything, it will be easier if you ever need to rebleed the system again
Old Sep 13, 2007 | 07:23 AM
Spec_Ops2087's Avatar
actually on all fairly new cars, after a certain speed air must flow into the cabin even if the fans are turned off. Thats why you'll be driving 70mph, windows and top up and still feel air coming out of the vents on all new cars.
Old Sep 13, 2007 | 07:31 AM
So its a law?
i have found that it happens on a much larger scale when i have the top down than compared to it with the top up etc...
Ek_Jak
Nov 21, 2015 04:13 PM
ry4nolson
Jan 19, 2012 07:54 PM
nte11igence
Aug 27, 2007 01:27 PM
Jenner
Mar 14, 2002 10:43 AM
S2Krazy
Oct 12, 2001 04:56 PM
