Anyone Have Helms manual on PDF?
i purchased the big book, and cant find it so does anyone have the helms on pdf so i can just double check something.. no copyright violations here since ive already paid the rediculous honda price for it.
thank you
riley
thank you
riley
Yeah I have it, downloaded it off this board somewhere. Check "The Library" section otherwise you can buy it on eBay for a few dollars (backup copies on CD that is).
i click library and the tSB is full of stuff ..
ijust wanna pdf of what i had.
need to remove oem heat sheild(the big one thats next to battery, not the header shield.) cant figure out how to get the back bolt out.. i really dont wanna have to go under car but seems header will be in the way if i do.. so idk
riley
riley
IIRC, you don't take the last bolt out. You loosen it and the heatshield will slide up. You loosen the bolt from above. I use those mini box wrench with a one-way clutch on the closed-end. Small hands also help (I'm 120-ish lbs).
thanx, i was looking at it and saying SON OF A BITCH.
the other ones look easy to get to. worst case scenario i can use a wrench instead of socket prolly fit perfect
thank you miataman ;-)
Thomas Guide
12-07-2018 10:39 AM
s2000maniac
09-11-2011 04:24 PM
