ANYONE WHOSE BEEN IN THE DOORS OF THE S2K!
Old Mar 22, 2008 | 05:15 PM
teanza's Avatar
noone has had the doors apart, eh?
thanx in advance just in case!
~tina~
Old Mar 23, 2008 | 04:39 AM
billo's Avatar
I have replaced my driver's side window regulator. but it has been 5 or 6 years. As I recall, the motor is at the bottom of the door. This cables run in a 1 inch wide riserthat runs from the motor up to the bottom of the window. This is pretty thin gauge metal. It's possible that this piece was bent when the PDR man was leveraging his tool. The door panel is easy to remove and will go back together as good as new. Google Majestic Honda Parts and do a drill down for the Power Window motor/regulator. You can price the part and see an illustration of the door internals.
Old Mar 23, 2008 | 04:46 AM
billo's Avatar
Okay, I just looked at Majestic. After drilling down, you will find the illustration under Door Windows. Looking at the picture, you can see the metal riser. It is a track for a carrier that holds the window. There is also a cable run from the motor to the window carrier. But, I don't see how this could be damaged. I remember this being flexible. I'll stick by my earlier conclusion that the track is bent.
Old Mar 23, 2008 | 05:13 AM
HonCBRf2's Avatar
Stop being a wuss and pull the panel...There is only 3 screws holding it on and all you have to do is pull from the bottom to pop the snap thingies...
Old Mar 23, 2008 | 06:36 AM
Ubetit's Avatar
Old Mar 23, 2008 | 08:13 AM
teanza's Avatar
haha ok. i looked @ the illustration @ majestic, billo. will pull the panel later today and post results! thanx!
i may be posting pix, as well.
~tina~
Old Mar 23, 2008 | 09:10 AM
Avionics86's Avatar
They probably bent the rear track if they used it as a lever. The front track is pretty stout. Either way you need to pull the panel and it's a messy job with the sealant around the plastic barrier. I hit a deer and got a used door and switched out all the inner workings. PM me if you want me to look at it. I live in Saint Cloud.
Cant Believe I Own A S2K
Jul 14, 2015 05:23 AM
takito sexy!
Mar 14, 2014 04:48 AM
SuzukaS
Sep 21, 2006 10:20 AM
esracer
Jan 10, 2006 08:47 AM
ayelien
May 22, 2004 09:17 PM
